LED Replacements for Halogen High Beams
dieselscout80
Apr 23, 2022
I have the halogen lights on my Ram 2500 I don't want to swap to LEDs for low beams due replacement LED bulbs scattering light and are hard on other drivers.
However, I was wondering if there is a replacement LED bulb for the high beams and if it would be worth the cost as it would not be a issue for other drivers.
G Mcpherson
Dec 20, 2020
Yacolt, Wa
I would imagine the effect would be the same. I purchased these and modified the Tabs to fit. Better lighting but not like a True LED or HID Light.
Philips 12361B1 H9 Standard Halogen Replacement Headlight Bulb, 1 Pack​
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
I used gtr brand before I went oem led. they were crazy bright. operated well on the truck.
deanfx
Jul 2, 2023
I just did and did NOT see a high beam replacement bulb.
dieselscout80
Apr 23, 2022
I saw that one, but their vehicle query tool does not list it as a Ram 2500 high beam bulb.
I wonder how much brighter it will be vs the factory halogen high beam bulbs?
deanfx
Jul 2, 2023
9005 is like an H11, just standard size bulbs. I never change my high beams, just my low beams. And the only reason I don't change them is in case the low beam LEDs go out for some reason that will probably never happen, I'll have the high beams. Plus I never use the high beams anyway. I'm just weird like that. But I do use Diodedynamics low beams. And even use Sylvania low beams before in LED form from Autozone with good results.
I can't speak for the brightness of the high beams. But if you try them, let me know your results.
I had GTR CSP mini’s in the low/high/fog lights on my 18. I’d did have the projector lows, but the fogs and highs didn’t scatter light like other LED’s I’ve seen and the light was excellent.
