KAODtech bypass
IvanDeSlaer
Aug 8, 2023
I just connected my bypass on my 2019 2500 RAM per the destructions. I'm waiting for OBDlink but I took my scantool and I wasn't able to talk to the truck anymore. Is this normal? I did the search a few different ways but I wasn't able to find an answer.
Thanks in advance.
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
are the wires still color coded to the terminal block base colors? they used to have a heat shrink wrap rotating which side each plug goes to.
IvanDeSlaer
Aug 8, 2023
This is what I have. The blocks are green/black & green/white. I installed the white connector to the G/W and the black connector to G/B. Then the male OBD to the truck. My scantool to the OBD on the harness and it won't talk to the truck. Am I missing something?
IvanDeSlaer
Aug 8, 2023
I reversed the previous installation and now everything works. I installed the BLK connector to the G/W block and the WHT connector to G/B block.
It's the wire colors that matter*.
It's literally posted in a pic in the 1st post in the ALFAOBD sticky thread.
* Seems one wire color can be different on the GRN/WH (GRN/PNK), but YEL/BLU goes to the BLACK base CANBUS block nearest the headlight switch (dash).
I don't understand why TF he's building these with the black/white connectors back-assward and useless dated instructions. It causes no end of confusion here.
drpringle
Mar 27, 2024
How do you get the cables out is my question
Mine are stuck in there were do you push to release
CdnHO
Nov 17, 2020
Ontario
Once you get the connectors out just remove the lock tabs to make future removal pain free. I learned that the hard way was as well. The connectors stay in just fine without the tabs.
Grateful Dad
Aug 21, 2021
Georgia
Not sure if I have an updated version but on mine each leg has what looks to me like color coded bands (green/black and green/white) to match the correct block.
Blue/yellow wired plug goes to block with black base
Red/green wired plug goes to block with white base
I’ll find out soon, finally ordered the vlinker and bought a license for Jacan.
Mine was like that too atleast the white and black bands, that was a a couple years ago
Grateful Dad
Aug 21, 2021
Georgia
Well, harness worked like a champ! Adjusted TPMS thresholds and activated Bambi mode. Whole thing was pretty darn easy.
