Kaodtech bypass cable installation questions
FE427TP
Feb 23, 2024
1.) Is it necessary to unplug the battery before attaching CanBus connectors?
2.) If I disconnect the battery do I just need to remove both of the negative cables? (Diesel truck)
3.) Is there any codes or anything I need before disconnecting the battery to prevent stuff from being locked out?
No just plug the connectors in, no need to disconnect the batteries, if you do pull the negatives nothing is needed after reconnecting them
