It feels like my hood is going to blow off!
Golfnut
Oct 25, 2021
I purchased a 2022 Laramie about 6 weeks ago. I absolutely love the truck but the hood scares me to death. When driving into a strong wind the front corners act like they are going to peel off. My 2017 Expedition does the same thing. Do I need to worry about it? Is there a cure?
The nature of aluminum hoods you are fine you can adjust the bump stops a bit to make it a bit better
Wholeo
May 12, 2022
I see you mentioned a Ford Expedition, I drive a 2018 F250 for work and not only does the edges raise the whole dang hood dances, used to scare me to death and it's so bad the aluminum around the catch that latches is cracked, I'm used to it now. I got my Ram back in July and have only put 1,000 miles on it and I really hope it won't suffer the same hood problems my work truck does, I work a lot
Will_T
Jan 23, 2021
Southwest Oregon
Mine did the same, especially when passing an oncoming semi in the adjacent oncoming lane. There was a long thread about this a while back. I played with the bump stops a bit and that did not help. Finally followed a recommendation to put some pads on the non-adjustable stops. That fixed it for me. See posts 169 and 171 in this thread: https://hdrams.com/forum/index.php?threads/hood-vibrating-at-highway-speeds.515/page-9#post-130057
jetrinka
Jun 11, 2021
Yup very common. Haven't been able to resolve it. Hood has never popped up though so I just ignore it now. The first time it happened bad though I almost crapped my pants thinking the hood wasn't latched
flan
Aug 16, 2019
Haven’t heard of one blowing off yet, but heard of plenty shimmying. Adjust the stops, it’s too bad they don’t come adjusted from the factory like they should but I guess it’s a common issue across the brands since they have been going with weight saving materials to increase tow ratings.
You should see mine flap when i drive with my plow on! You would have to change your pants! Lol
Docwagon1776
Oct 29, 2022
I gave both my stops about 1/2 turn "up" and that seems to have resolved the vast vast majority of hood flutter.
Firebird
Sep 24, 2020
My 2019 flapped around, but thankfully, my 2021 doesn't
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
I've adjusted mine over the years and it's pretty good unless it's really windy, or passing a semi.
