Installing tpms sensors in 2021 RAM 3500
THook
Apr 10, 2021
I got the trailer tire pressure monitor system on my 2021 3500 which included 4 pressure sensors. I want them installed on my Grand Design Solitude 5th wheel, but I’ve had it at two different tire shops and both have told me the sensor stems were too short to provide enough thread to install them. Okay be looked for compatible sensors with a longer stem but no luck. Any ideas??
GBB
Jan 4, 2021
Have you talked to your dealer about them. I ordered them with my 2021 3500 also but haven’t gotten the truck yet.
THook
Apr 10, 2021
I have talked to the dealer and also another local dealer. Neither have heard of any problem installing these sensors.
steve49
May 9, 2020
Show Low, AZ
Did the tire shop actually take a wheel off and break down the tire to verify they won't work? I'm guessing your trailer wheels are aluminum, which I suppose there could maybe be a machining issues because of the wheels being thicker than a steel wheel? Then again the TTPMS kit comes with different thickness rubber seals, which I would assume would account for various wheel material thicknesses.
THook
Apr 10, 2021
Yes the tire was broken down. The hole in the wheel was 5/8 and there were the required seals and washers. I didn’t get to see the actual installation, just took their word for it. I’m going to break it down tomorrow and see if in fact there is an issue. Will report my findings.
GBB
Jan 4, 2021
What were your findings..
Bullpin22
Jan 11, 2021
So I ordered the same and didn’t receive any with the truck. Dealer says still on back order.
I asked around here on another TTPMS thread and these were recommended.
I can say for certain they paired with my truck on the first try and fit in my TT tires fine. It’s a GD 2250.
The stems are longer than factory rubber for sure.
No pics at this time but I’ll get some and measure tomorrow.
