no as I have been retired for a few years. What I am referring to is the weight you can tow. The way the state tow capacity is misleading because of the way they determine the load ratings
Well then what you're saying is confusing and misleading. The weight you can tow is not GVWR; it's tow ratings. And for years, pickup manufacturers have used the SAE J2807 towing standards, and that standard says nothing about reducing GVWR or tow ratings depending on whether it is a flat trailer or a box trailer.
What the SAE and manufacturers DO describe is the differences in tow ratings depending on the hitch type; with ball hitches having reduced ratings compared to 5th wheel hitches, compared to gooseneck hitches.
To me, if you are going to make definitive statements to challenge someone here, like "all manufacturers determine", you should have no problem providing a link to at least 1 manufacturers recommendations. Especially when you make claims about your years of experience, I find it strange that you would aren't able to provide any references at all. Retired has nothing to do with that.
I had years of heavy trucking experience towing both vans and flat decks, mostly with heavy equipment (over 100,000lb loads sometimes with boosters and jeeps and over 40 tires). With respect, I don't think you've towed with flat decks; wind resistance is far higher on many flat deck loads than with a box trailer. I've long since retired from the trucking industry, but if anyone asked me to provide up to date information about that industry, I could find at least some references within minutes.
But just in case I was missing something, I spent some time looking at the tow ratings from the big 3 pickup manufacturers. There is nothing in any of their tow guides to confirm what you are saying. And, just for giggles, I looked up their tow ratings from over a decade ago; still nothing like what you are saying between flat or box trailers. Didn't take long...
So, now I'm going to challenge the other statement you made:
"The way the state tow capacity is misleading because of the way they determine the load ratings"
Can you provide references, or any other information, to backup why you made this statement?
B
