High idle 6.4, programmable with VSIM?
CPM10V
Jan 2, 2023
Anyone know if possible to set up a routine with VSIM to command a high idle for 6.4 in park? I’ve seen commercial spec 3500 trucks w/ 6.4 have something like this if set up with a PTO so thought it may be possible. Only doubt might be Ram locking it out if a non-commercial vehicle. My truck is ‘24 2500 Tradesman/Power Wagon w/ VSIM option. Thanks.
Look at the bodybuilder site it should state which wire will be the high idle
Ewoodard
Apr 5, 2021
You can do it with Tazer Ram. Don’t know if they have Tazer for a 24 model.
jsalbre
Oct 29, 2019
ID
The only Hemi trucks with high idle are the C&C trucks. I be spent a lot of time trying to get it to work on mine and it just gives errors.
Looks like if you enable the PTO sales code then you can use the green connector to setup the high idle?
CPM10V
Jan 2, 2023
That’s a good idea. Is AlfaOBD the program for enabling options or Pulsar/Tazer?
