Grinding in 4H
Looks like you're lifted on larger tires (can't tell for sure from video clip). If so, the sound is similar to what we had with our truck after lift and bigger tires. Turned out to be the rzeppa joint on the transfer case side of the front drive shaft.
Only happened when in 4wd and turning left or right or the front suspension flexes when in 4wd. Stopped after the suspension flex went away or the wheels straightened out, or when taken out of 4wd. The fix for our truck was a double cardan front drive shaft. A lift with bigger tires is too much for the rzeppa CV joint on the stock drive shaft.
Are you sure 4wd fully engaged? You shouldn’t be using 4wd on hard, dry surfaces.
So an update. Dealership says something is wrong, but they first need to replace the driveline, so waiting on that part... hmmm
Sent from my SM-S916U using Tapatalk
Mine does the same thing. The dealership replaced the whole pumpkin but that didn't fix the problem. They now believe it's the driveline as well, but there is no current fix for it. They did say that Ram engineers are looking into the problem, for whatever that's worth.
This has been discussed in another thread and here is a company that makes a patented replacement driveline. I have reached out to them, but I'm giving Ram a little more time to figure it out before I plunk down $1300 + on a new driveline. https://drivelinesplusinc.com/2019-2023-ram-2500-3500-front-driveshafts/
I took a look at those earlier. Crazy to me that they aren't sure.... glad it's under warranty and eventually lemon law. I just need my truck back for a trip this weekend. Been at the dealership for over 2 weeks
That's just gone on my list of parts lol. Honestly I thought the double cardan was fine and I'd rather lube one than randomly have a CV joint fail. From a durability perspective serviceable parts that are more durable are why I drive a 2500 and not a max tow/payload halfton configuration that could do what I need to do... that and the 6.7 is just great for highway fuel consumption.
Update:
Dealership, after 1 month! Finally returned my truck because they are waiting on parts. They first replaced the driveline, didn't fix the issue. Opened up the transfer case and found metal shavings all over. Now we are waiting for a new transfer case, gears that is.... what a pain!
Update:
Did you find a solve for this? I am currently having the exact same issue. Truck went to dealer end of June, just getting it back today. The did front shaft and replaced the T-Case (metal shavings). Tech said spider gears have some pitting as well, but not out of tolerance. He said it still is making the grinding sound in 4x4, and has drive shaft slap still (front to back). He's suggesting drive it for 90 days, then come back for carrier bearing. He also mentioned Ram Engineering is aware of this issue, and they have 3 other trucks in for this as well. He thinks something to do with CV vs U-joint shaft, but can't be sure. There is a Ram tech forum he's in, and there are a lot of techs discussing this with no real solve. So wondering if you found one. He also suggested a drive line spacer (I have 6" lift with 37x13.50x22, big offset on a 19 2500 6.7).
I'm thinking at this point, heck with a spacer, I'm swapping out the front shaft for a 1410 double cardan, Adams Driveshafts makes one as well
Nope, they called me today and said they finally got the T Case!!!! That took a long long time!!!! Total joke. I'll keep this updated. Truck goes to the dealership on Wed.
Yeah mine was there for the entire summer waiting on a tcase, got it back on Friday. Didn't fix anything. Back to the dealer it goes. I'm pretty convinced it's the carrier.
Did anyone ever get theirs fixed on this? I bought a 2022 2500 a few months ago and put it in 4WD recently and have noticed the same issue. Mine has a 5” lift and 37’s purchased like that from the dealer. I moved out of state and wonder if this is going to cause issues with any sort of warranty. Thanks
I just tried my 2019 4wd for first time. 35k miles on it. And in 4wd when turning from complete stop. It is clunky noisey and doesn't feel good at all. But when going straight I don't feel or hear anything. I only have a leveling kit on 35s. It almost feels like it's binding and doesn't want to roll (mind you only tested quickly in my court in front of house which is asphalt... But when our back in 2wd. Smooth as butter and steering wheel is easier to move. It's 2019. I got it used. Not under warranty.
Don't run 4WD on dry pavement/asphalt. You'll get the result you got.
From the owners manual
The 4WD HIGH and 4WD LOW positions are
designed for loose, slippery road surfaces only.
Driving in the 4WD HIGH and 4WD LOW positions
on dry hard surfaced roads may cause increased
tire wear and damage to the driveline components.
Yea I read that on the forums. I was just curious on how to put it in 4 since I never tried it. And did it in front of my house and was wondering if it's just the 35s on the asphalt. I'll try to find some dirt field near me to see if it still does it.
It will unless its loose sand or snow. Thats how it should work
