I have a 2022 3500 Limited Longhorn with the big display. Every so often while using the Nav with a destination entered we get this voice message that sounds like “No Lo Lo”. What the hell is that all about? Told you it was a goofy question….
I use the built in nav quite a bit, as I like the nav display on the instrument cluster (‘23+). I’ll keep an ear out next time I use it for something that sounds similar to what you’re describing.It doesn’t do it if using CarPlay, only when using the Ram built in Nav. Both the CarPlay using my IPhone as well as the Ram Nav is useless for my application, I pull a 42’ 5th wheel and they will put you in some bad spots. I’m going to use Garmin made for RV’s when pulling the trailer.
The nav system has no awareness of a trailer being connected, or of routes better suited for trailering, regardless of some marketing materials previously released mentioning “Trailer Routing”Lastly, I too wonder the wisdom of using TOM TOM. I wish there was a way to choose and verify a RV/Trailer route. I think it currently senses when trailer/tow mode is activated.
I drop my truck off tomorrow, and will update when a "fix" is found.
Thanks...The nav system has no awareness of a trailer being connected, or of routes better suited for trailering, regardless of some marketing materials previously released mentioning “Trailer Routing”
