GODZ_MFG
Hello HDRAMS Members and Viewers!
My name is Drew and I am co-owner and operator of GODZ MFG based out of Castle Rock, Colorado alongside my partner Grant. I wanted to jump in here today to introduce you to our new product, the PowerHouse, which is your ultimate wiring solution in your HD truck.
A brief history first, prior to owning my 2022 RAM 2500, I had a very built Tacoma, and while that was a great truck both to drive and to wrench on, it no longer met my needs. One thing that myself and Grant have always nerded out about is wiring. With more and more electrical products entering the truck market, that meant more and more clutter in and around your engine bay as you tried to wire your 612 accessories. We started this company with the goal of offering a dedicated heavy duty marketplace designed for off roaders, overlanders and powersports enthusiasts alike. While we do sell products that we don’t manufacture but very much believe in, we also want to take our years of knowledge and experience to help bring you suitable and easy to use products for your HD trucks.
With all that being said, let’s talk about the PowerHouse. As previously mentioned, the PowerHouse is the ultimate wiring solution in your HD Truck. The PowerHouse is offered in several configurations currently including OEM Upfitter/AUX switches and the Switch Pros SP9100. Soon to come, the sPOD Bantam and Garmin PowerSwitch will also be available options.
At this point you are probably thinking, okay, but what else can it do? Well, we are glad you asked. All of our PowerHouse solutions not only feature the mounting points for your selected switching unit, but they also feature an auxiliary fuse block, common BusBar and depending on the switching unit, a terminal block to more easily add accessories.
Below is a breakdown of the individual components included in an UPFITTER/AUX SWITCH kit and what the purpose of that specific component is.
Below is a full gallery of photos and also a link to a YouTube video more thoroughly covering everything.
If you guys and gals have questions, drop them here in this thread or feel free to contact us directly through our website. www.godzmfg.com
Here is a detailed video showing you more:
And last but not least, here is a specific link to this product on our website!
- GODZ MFG PowerHouse Foundation - This is the ⅛” thick mounting plate that all of your individual components will mount to. This plate is either aluminum or stainless steel depending on the configuration and is also powder coated in a wrinkle texture black to provide a finished and clean look while enhancing its corrosion resistance.
- 100A Waterproof Circuit Breaker - The circuit breaker is designed to take the power from your battery and safely push it through your panel. If there were to be an overload or short in the system, your breaker would trip thus protecting all of your accessories and more importantly, your vehicle’s electrical system.
- 8 Circuit Compact Fuse Block w/ Cover - The purpose of the auxiliary fuse block is to get rid of all of those messy In-Line fuses. In-Line fuses are great for convenience but they leave a lot of leftover wires that add up really quickly. The auxiliary block is in place to replace up to 8 inline fuses where you can connect accessories like fridges or radios that may require constant power.
- 10 Gang Common BusBar w/ Cover - The common BusBar is very simply a location for you to ground all of your accessory wires instead of crowding a body ground around random locations on your rig.
- 6 Position Terminal Block - The terminal block allows you to take all of your trigger wires from your OEM Upfitter/Aux switches and permanently mount them in an easy to access location where lighting or other switched accessories can easily be connected.
SHOP ALL POWERHOUSE
Accessories For Your Heavy Duty Trucks 100s of Accessories - 24/7 Support
www.godzmanufacturing.com
