My 2019 did the same thing. Dealer did a manual regen but it kept doing a burn every day. Eventually I emptied the DEF fluid, refilled and cleaned the DEF injector. I was surprised at all the white crystals almost blocking the injector. Sprayed the injector with water and it cleaned up without issue. Do not spray into the hole, I used a damp cloth and managed to pull out the urea deposits.
Reassembled and presto, the truck burns are now as per usual. I now go to a different truck stop for DEF and check to make sure it’s 2.5. I did not realise DEF has a use by date as it is organic.
Every service interval I now pull the DEF injector out and give it a clean. Have done nearly 75k miles since then and it’s never played up.
What I don’t understand is how the DEF injector affects the DPF.
