jak
Anyone have fluid film applied? How long does it last? Is it worth it? Thanks
Then I decided it wasn't worth it. When I add up the expense over the years, I just don't feel like it makes sense.
I did, and let it dry of course. I was starting to see a little bit of rust in various areas of the frame and weld points. Fluid film definitely migrates its way into every crevice. For me, I want 350k miles out of my truck, and still hopefully have original panels, doors, and a solid frame. The diesel engine will make it that long, so it’s worth making the body last as well imo.Those of you who use it, do you power wash the underside first? I assume so, but just straight water. I'd assume any soap in cracks and joints would reduce the effectiveness.
Tape is the norm, rubber plugs are available for them though.Does anyone know if these holes that have tape over them, are supposed to be rubber plugs? Was this a mistake, or are the holes for ventilation? All I know is water/ moisture will get in there and rust out the pillars. I’m going to spray in every hole with fluid film
Curious where there is tape. I paid to have mine sprayed, but it sounds like this could have been something missed that I should check on mine.Does anyone know if these holes that have tape over them, are supposed to be rubber plugs? Was this a mistake, or are the holes for ventilation? All I know is water/ moisture will get in there and rust out the pillars. I’m going to spray in every hole with fluid film
Every 10” the whole way from fender to fender on both sides just below the bottom of the doors. Typical place for rust in less than 10 years.
