Fishnerd’s Build Thread
It’s WAY harder in any uncomfortable position lol looks good tho!
Oh yea thats NEVER fun especially overhead when you have to be directly underneath due to the location! But when it burns in perfect and pretty it makes it all worth it!
Wow!!! I want to get to that level! That looks awesome, mine just look like blobs haha…i need to keep practicing..
I have burned thousands of pounds of wire, dont expect to get great overnight it takes practice. And prep and cleaning is key!
Your welds are not bad i have seen far worse from licensed welders.
You have some really great attention to detail with your build, i look forward to seeing what you do next
Been awhile since I posted anything, but figured the latest “mod” could potentially help some folks. I havent been driving the truck much and the recent cold weather seems to have zapped the battery. Figured it was time to put it on a trickle charger.
Initial plan was to run a sae cable from the battery to the rear of the truck, but after some testing I found that the trailer 7 pin was constant hot. So i built the an adapter to be able to maintain the batt using the existing wiring…
I mentioned this a while back in a thread about charging batteries it works quite well and these days pretty much universal as most vehicles have a 7 pin other than small sedans
What brand is that 7 pin? I have never seen one with an anti strain like that before
Oh man wish i had saw that post it would have saved me the testing , but glad I arrived at the same place, if you dont mind can you please reply with link? By “anti strain” i assume you are referring to the yellow? If so, its actually built up (layered) heat shrink. It allowed for complete sealing and visibility so I remember to unplug before driving off.
The part that holds the wire in the 7pin
"The part that holds the wire in the 7pin"
isn't that just a cable gland , waterproof wire pass through?
