Falken Wildpeaks A/T3 W
mr wayne
Aug 3, 2021
Could someone give me an actual height on a mounted 295/70/18 ? Thanks
Falken says it's 34.3" but I asked for an actual mounted measurement. Is this what you posted?
34.3” is the unloaded and inflated height.
It’s not static height, but rather rolling height. It’s the effective height of an Installed tire. Static height will be slightly taller, since there is weight on the bottom half of the tire.
What are you trying to do with the measurement.
mr wayne
Aug 3, 2021
Have some on order. Just trying to see what height is mounted on a truck. Ground to top of tire measurement. Have cooper same size now and wanted to compare mounted height.
Compare rev/mile and you can see if there is a difference. That's going to be more accurate than someone with a tape, unless the weight and pressure are the same.
mr wayne
Aug 3, 2021
Got it. Thanks. Coopers are 607 and Falkens are 609. Shouldn't be hardly any difference.
