I've never seen a listing for EBC extra duty for the 19+ HD trucks.
I ran EBC green stuff on my Audio and they were a great stage 1 type upgrade and low dust. They make a great product, but unsure they have any fit for the new HD truck rotors.
I put Powerstop on my Audi last change and they kinda suck. I know it's a different application, but the OEM replacement kit with geomet coated rotors and what should be an equivalent pad, are soft.
I see the powerstop z23 and z36 kits for my truck on rock auto (2019 truck) how do yall feel about drilled and slotted rotors on a tow rig? My gut feeling says to stay away from themIt appears that EBC makes a kit for 2019 trucks at least (link) obviously powerstop also makes a kit as indicated (link).
I'm looking at potential upgrades myself, as the OEM brakes are good, but with all the extra weight it would be nice to upgrade without blowing the bank on something like the SSBC kit (link)
Personally, drilled and slotted doesn't concern me on a highway truck. On a more off-road oriented one I'd be more nervous about small rocks and debris getting into the drilled portion and causing premature wear or cracking the rotor.I see the powerstop z23 and z36 kits for my truck on rock auto (2019 truck) how do yall feel about drilled and slotted rotors on a tow rig? My gut feeling says to stay away from them
I am not saying you're wrong, but I can't imagine there is much difference in weight from something like the OEM to the Powerstop drilled/slotted rotors. I don't know what the temperature difference is between a solid rotor and one that is drilled but imagine it's a bit considering basically every sports car on the planet now comes with them standard from the OEM. Obviously the slots are going to help a lot with keeping the pads "surfaced" but at the cost of shorter life.Solid rotors have mass. That does more than the offgassing needed with drilled and slotted in our application IMO. That’s what I was after. Pads are pads. Semi-metallic bite better but dust up. Ceramic do the job and keep our wheels cleaner. I will be the guniae pig for the cheap Powerstops. Review to follow. My life is a money bleed so it’s just another thing lol.
Sent from me
Just out of curiosity, why don't you see them as appropriate? Are you worried they won't last as long or something else?I just don't see slotted or drilled rotors as an appropriate fitment for a tow rig.
I'd never use them on my 3500.
What I really want to see is for someone else to buy these NRS pads and compare them to OEM so I know where to spend my money when it's time. I don't think the Powerstop are mechanically bonded and that concerns me some.
Search: 3 results found for ""NS2223" OR "NS2224" OR "NS2225" OR "uapt_fitment_search""
Get the best brake pads from NRS Brakes. Our patented design and 30+ years of experience deliver the longest-lasting, best-performing pads. Shop now!nrsbrakes.com
I'll be curious of what your thoughts are after you've had them a bit.
P.S. If you're gonna just be bleeding money out, is there any chance I can ask you to pickup a calibrated power STR and let me know if it's worth the coin?
Damn I’m at 38k miles and it’s looking like I could make it to 50. I don’t think the factory brakes are great so I get wanting to upgradeI just rolled 26K. I have had a thumpy pedal for a while. If I had to guess….since about 10k or a cple years ago. During a visit to the dealer for an oil change/rotate and the tailgate recall I asked them to check the brakes. Their answer was to drive the truck more. The piston side of front rotors are crusty. The rears don’t look horrible but may have some pad deposit. Lots of pad left front and rear.
The real jab here is I would consider us flat landers and I drive the truck like a grandpa. Yes, we tow the 5er but never have I had a situation where the truck brakes heated up from heavy use enough to warp rotors. Disappointed in the factory stuff for sure.
