2019 2500 had 50,200 on first dealer trip to fix warranty and recalls. Has 52,234 now
Had a particulate filter sensor code and the dealer could not get the part and let me take it home and drive it after fixing all the warranty work. They were supposed to call when the part was available but never did. Finally got the 'DPF Filter full. Reduced Power. ‘See Dealer'
I finally called another dealer, and they had the part and installed it then did a manual regen which got the DPF gauge down to 25% when I picked up the truck. I drove it for .5 miles and went into regen then the 'DPF Filter full. Reduced Power. ‘See Dealer' message again. Went back to dealer and they still have the truck.
Dealer can't seem to solve the issue. They opened a STARS case (83843815) for help. My DFP screen never moved off zero in 40,000 miles and before all the issues would regen once in a while ( I never checked the hours in between).
Why can't the issue be narrowed down to either a software issue or a sensor/component.
-Sensors cause the codes.
-Check all sensors manually. All ok?
-Check sensor wires at the PCM. All ok?
-Software issue?
I understand it could be complicated but not impossible to solve.
-Software issue?
