dinks
Dinks
Jan 19, 2022
hey all,
I have 2020 2500 tradesman. I recently added some new wheels. I still have the factory tires on the new wheels. they are set at 65 psi. a buddy told me when your not towing to bring the tire pressure down to about 50 psi to save on tire ware. i was wondering if anyone else has heard of that
flan
Aug 16, 2019
I run 55 front and 45 rear when not towing a heavy load a long distance. More even edge to edge tire wear and smoother ride is a benefit to doing so.
Dinks
Jan 19, 2022
OK thanks much appreciated
Dinks
Jan 19, 2022
flan
Aug 16, 2019
No problem, welcome to the forum. One thing I failed to mention is the TPMS May have to be recalibrated depending on your model unless you don’t mind the dash warning light being on.
Dinks
Jan 19, 2022
I has les schwab recalibrate the TPMS and it didnt work
flan
Aug 16, 2019
AlfaOBD and the AEV procal snap are 2 good options for recalibration.
Crusty old shellback
Apr 10, 2021
I run 45/40 in my power wagon when running empty. But I've changed tires to BFG KO2 35s.
Best bet is to look up a tire inflation chart for your specific tire and see what pressure they recommend for your truck weight. Most will be down around 35 to 40 PSI. 65 is for when the truck is fully loaded to max weight. even then, it's a bit high.
Depends on tire load range 65 is not enough for a loaded E range tires at max gvwr….. OP the best way to do it with your truck unloaded is to do the chalk test…. And unloaded +- 500lbs on my 19 T man 2500 i run at 60 it gives the best wear pattern
