Just filled my def and on vacation now check engine light on and def reading empty .what can I do ?
D donf New Member Joined Mar 29, 2022 Messages 3 Reaction score 0 Mar 29, 2022 #1 Just filled my def and on vacation now check engine light on and def reading empty .what can I do ?
H3LZSN1P3R You're doing it wrong Joined May 29, 2020 Messages 9,337 Reaction score 8,536 Mar 29, 2022 #2 donf said: Just filled my def and on vacation now check engine light on and def reading empty .what can I do ? Click to expand... Did you fill it all the way? If so you have to drain some as they need an air gap in the tank for the crappy ultrasonic sensors to read the level
D donf New Member Joined Mar 29, 2022 Messages 3 Reaction score 0 Mar 29, 2022 #3 Who can I d H3LZSN1P3R said: Did you fill it all the way? If so you have to drain some as they need an air gap in the tank for the crappy ultrasonic sensors to read the lev H3LZSN1P3R said: Did you fill it all the way? If so you have to drain some as they need an air gap in the tank for the crappy ultrasonic sensors to read the level Click to expand... donf said: Just filled my def and on vacation now check engine light on and def reading empty .what can I do ? Click to expand... how do I drain some? Click to expand...
H3LZSN1P3R You're doing it wrong Joined May 29, 2020 Messages 9,337 Reaction score 8,536 Mar 29, 2022 #4 donf said: Who can I d Click to expand... Siphon some out or pull fill line off of tank and risk a small bath
D donf New Member Joined Mar 29, 2022 Messages 3 Reaction score 0 Mar 30, 2022 #5 Can I just run truck till it uses the def?
H3LZSN1P3R You're doing it wrong Joined May 29, 2020 Messages 9,337 Reaction score 8,536 Mar 30, 2022 #6 donf said: Can I just run truck till it uses the def? Click to expand... You can try if you are pulling a trailer you may be ok but unloaded you may not use enough DEF before the count down limits you at 5MPH
