Dash crickets - squeaks over bumps (FIXED)
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
I have a squeaking that sounds like crickets chirping. Light imperfections on the road and it will squeak/chirp.
Seems to be coming from the top left of the dashboard. Maybe behind the gauges or near the speaker by the windshield. I’ve laid under the dash and reached around up there and don’t feel anything wiggling or moving, but I don’t have great access.
Anybody else have a squeaky dash? Find the culprit?
madmax4073
Jan 2, 2021
mine too, stealership had my truck for a week and said it was the heater core hose, said it was fixed and still have the squeaks.
Cgptv
Dec 20, 2020
Harrow Ontario
Two 7 mil screws and you pull the lower panel below the steering wheel. You have to look straight up and to the left towards the left fender there is a steel round tube that runs left to right. Look between the amp. and the side wall on that tube
Rockcrawlindude
Jan 1, 2021
Georgia USA
Thanks. Just checked it out. My amp is rock solid.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Just for good measure, I removed that amp support bolt, checked it for damage (not sure why it says they break) and it seemed fine. I reinstalled it at 44in/lb per the instructions.
I don’t think that was the issue since my amp was tight, but it gives me peace of mind to move to the next step of the search for the noise.
jbncccb
Apr 19, 2020
My 4x4 button panel has developed a noise. Think I may pull the panel and add a little electrical tape if there is enough room.
Sent from my ONEPLUS A6013 using Tapatalk
Rockcrawlindude
Jan 1, 2021
Georgia USA
Hope you get to the bottom of it. I know this squeak drives me crazy. I have a floor shift transfer case but I still may check that panel.
Rockcrawlindude
Jan 1, 2021
Georgia USA
I removed and retorqued that bolt the other day and I didn’t hear the squeak for two days or so. Now it’s back and worse than ever. I’m going to replace the bolt and see what happens
Rockcrawlindude
Jan 1, 2021
Georgia USA
Ok so I haven’t found the source of the noise but I did install fox 2.0s on the truck and the ride is smooth enough that the noise no longer occurs (so far!) just a lucky coincidence
Epsilon Plus
Sep 11, 2020
Have the A/C TSB done and let them tear it apart. When it goes back together, it will either fit tight and fix it or you can tell the dealer "hey, what happened?". :D
Rockcrawlindude
Jan 1, 2021
Georgia USA
I think I have pinpointed the noise.
I now believe it comes from the drive side wiper assembly. I heard it today, parked, while wiping the windshield. I got out and wiggled it with my hand and it makes the exact same noise. I was able to get it to stop. Now to find out how to stop it permanently ( if it returns again)
dgstandard
Nov 27, 2019
My 4x4 panel is chirping now. It stops somewhat when i apply pressure to it. It sounds like there is something right behind the panel that is rubbing. What did you find when you pulled the panel?
jbncccb
Apr 19, 2020
Mine was rattling l while driving off-road on a deer lease. I had planned on popping the switch out and wrapping some electrical tape around it. However, since I've only been doing highway driving it isn't rattling and thus I haven't done anything more with it.
Mine was doing exactly as you say, when applying pressure it would stop.
