jared43758
- Joined
- Aug 10, 2019
[/QUOTE]What do you mean by this?
Also this is not a first off the line truck. I ordered 9/16/2019. It was build by end of September
UOTE="1HasBeen, post: 13014, member: 80"]
Just another problem waiting for a reflash
These trucks were rolled out so late in the model year, yet still have a lot of half-baked stuff.
[/QUOTE]So by flash you just mean apply most recent updates to ecm that current trucks being made are being used, likes fixes or improvements, like iPhone updates?
QUOTE="elephantrider, post: 13031, member: 781"]
some folks subscribe to the theory that fca pushed these trucks out without a robust ecu tune, so the
dealers flash updates almost anytime your truck is there.
The EVIC msg you have post update has to be associated with the supplemental cabin heaters - there's three of em. The rough running/chugging is, anecdotally, normal for these engines during the first couple or three minutes of operation when the OAT gets close to freezing, especially if the truck has a single alternator. Consider that the grid heater is drawing upwards of 200A when it cycles on. Then there's those supplemental cabin heaters trying to work too. And, if it's cold enough, the fuel filter heaters and DEF line heater will be asking for juice. And all that doesn't include the cabin demands for power (HVAC blower, heated seats/steering wheel, radio etc). Watch the volt meter after a cold start. The voltage will swing back and forth from the low 11s to mid 13s as the grid heater cycles. The rough running/chugging is simply the engine's attempt to maintain idle speed while the batteries are being pounded by the massive elect load.After I had my update my truck now says upon startup “cabin warm up in progress” on the dash. But it’ll start and run smooth for a couple seconds and when that message kicks on it will run pretty ruff until the high idle kicks in which it doesn’t always and I’m not sure why on that. Idk if the cabin heater electric drags the motor down so much it makes it run rough, I wouldn’t think, or something which the egr process chokin the motor to get the engine to warm faster. I’m going to stop in a couple weeks to get my trans updated and will check then to see if they have a update fix for the engine idle
