Burn'n Oil
It's a metaphor!
Quite by accident (brain fart), and contrary to what the Diesel Supplement to the OM states, I discovered that engaging the Idle-Up Feature with the speed control switches (cruise control) does not require the parking brake to be set. Put it in park, take your foot off the brake pedal, press the speed control button and then the accel/resume button. Engine RPM will increase to 1100 RPM. I use the Idle-Up Feature frequently when making short stops in the nasty cold so as not to be beating the batteries up with the grid heater via repetitive starts. I'm also a advocate of using the parking brake frequently just to keep it working although not always when parked on the straight and level.
