I'm hoping for a recall, noticed what looked like metal flakes the last time I changed the fuel filters.
I wonder which replacement fuel pump the kit contains?
so it's still the second attempt glitter bomb.36. Reprogram the PCM with the correct Sym Cam Injection Pump calibration. Please refer to all published TSBs regarding Fuel Injection Pump identification, and PCM reprogramming procedures.
My first fuel filter changes are coming up in 30-45 days.. Going to go over them with a fine tooth comb myself. Fingers crossed.I'm hoping for a recall, noticed what looked like metal flakes the last time I changed the fuel filters.
That sounds like a generic repair proceedure for a blown CP4. I can't imagine they want to keep repairing thousands of units rather then just replace with updated pumps to eliminate what I guess is a COSTLY warranty repair.. I guess we will know in a month...Tic Toc.....
Are you guys saying that a fix is in the works, but the fix may be simply replacing the CP-4 with the very same pump?
Are you also saying only failed trucks are to be fixed, and there wont be a recall, but more of a fix what fails and a "campaign"?
WTF?
So like everything else, it is a fact finding to see if anything should be done moving forward.Possible recall of Porsche Taycans for sudden power loss:
The fuel pump assemblies in these vehicles may have been produced with burrs inside the mixing tube that could prevent the transfer of fuel from the secondary side of the fuel tank to the primary side, which could obstruct fuel flow to the engine. At low fuel levels, the engine may not receive adequate fuel and the vehicle may unexpectedly stall. A vehicle stall without warning could increase the risk of a crash, especially at high speeds.
2019-2020 RAM 2500/3500/4500/5500 vehicles with 6.7L Cummins diesel engines could experience fuel system failure far worse than any other recently recalled vehicle. Stellantis has decided to not give a $#%! and focus on cranking out 2021/2022 models with fixed pumps because they already got the other suckers money and need more. Several people mad about the issue have traded in or sold their vehicles and replaced them with other Stellantis products, so the company has not seen a negative impact and will continue to give no $%#@s. As part of this non-recall, RAMCares will be instructed by the NHTSA to rename their online PR division RAMDGAF
Gonna wait until at least July, but if you are a 19-20 owner, I’ve already tested the waters on mine (I’m in Canada mind you) but have been offered more than I paid brand new in 2019. If you really want out, now’s the time. For me I look at it like this, you’re not really getting ahead because up here anyway 21’s are going for almost full MSRP factor in 11% tax where I am, it’s a costly upgrade.Sold my 19 Ram 3500 this week, the potential long term $10k plus cost exposure due a CP4 failure post warranty was definitely a contributing factor for me to get out the 2019 Ram. Let alone being out of a vehicle for months while it gets repaired.
They addressed it for 2021. Right?I will be going back to Ford if Ram doesn't address the CP4 soon!
You know that Ford is still using a cp4 right?I will be going back to Ford if Ram doesn't address the CP4 soon!
