trueriderzht
- Joined
- Oct 9, 2022
What’s a normal running temperature for a 2011 ram 2500 cummins 6.7 when going up hill
With no load it was going between 206 and 212 but I’m in a hot country( Haiti) , so basically you telling me at 212 not to worry ?Gonna need some more details. Towing, if so how much, ambient temp, grade you’re pulling, etc. But, up to 215ish or so is pretty normal with a good load
Heck i would not worry unless it was surpassing 230 if towing heavy enough but you are in a fine range!With no load it was going between 206 and 212 but I’m in a hot country( Haiti) , so basically you telling me at 212 not to worry ?
Thanks man , other thing I have a red like looking like a storm that keep showing from time to time « see pic attached « I was told it could be the power module that needs to be updated , I’m in Haiti the dealer doesn’t do it I call Dominican Republic since it’s next door , they don’t do updates neither . Base on that picc is it really the power module ? If yes I will Oder if new . Any help would be appreciatedHeck i would not worry unless it was surpassing 230 if towing heavy enough but you are in a fine range!
That's a low voltage light. Mine comes on every morning for a couple seconds until the alternator gets to work.
No thats not a low voltage light… the low voltage light is a red battery….That's a low voltage light. Mine comes on every morning for a couple seconds until the alternator gets to work.
