thestuarts
- Joined
- Jun 10, 2019
I have a 2019 Ram 3500 with the HO Diesel. I changed the oil at 4,200 miles, and I sent the OEM oil off to Cummins Filtration for analysis. The report is mildly concerning because 2 items came back with a rating of Abnormal.
Here is the full report.
- Copper was measured at 81 parts per million (ppm) which is considered moderate. The lab wrote,"Suspect most of the copper may be coming from the lubricant cooler and/or EGR cooler (as applicable)."
- Slicone was measured at 37 ppm which is considered moderate. The lab wrote, "SILICON sources can be abrasives (dirt, Alumina Silica), seals and gasket material, lube additive or lube supplement, and/or environmental contaminant."
