downsc123
Off topic but why wouldn't you just go with a travel trailer or 5th wheel if you want more space - I guess I don't understand the draw of a slide in and having to carry all that payload
Exactly. “I’m going to massively exceed my payload so I can tow a sketchy overloaded trailer on an unsafe hitch extension.”Major footprint difference, and often people go with a slide-in to be able to tow something else.
That’s nearly as heavy as my 28’ travel trailer when it’s empty. More than my previous single axle 21’ when it was loaded. Braking must suuuuck.FWIW that's an Eagle Cap 1165 based on the slides. Dry weight without options (without AC, awnings, Generator, etc etc etc) is 4917. With options, food, water, etc that thing is 6k give or take.
Eagle Cap 1165 — Eagle Cap
www.eaglecapcampers.com
They aren’t really any stronger (3500 vs 3500), just more suited for up fitting. Now if you’re talking 4500/5500 vs 3500 then yes, they are stronger.
Even the 3500 c/c frame is huge right at the back of the cab. I bet it's a foot high but I haven't measured. It's just very noticeable. It jumped out at me first time I was under the truck.Yea 4500/5500
Oh yeah. there are definitely more sensibly sized ones. This one is just comically oversized.All kinds of different sized slide-ins, most aren’t this level over oversized…
You could absolutely tip the truck up till the front wheels come off the ground and the frame would be fine. It's shock loading that causes the bend. The frame would have to be significantly larger/heavier/stronger to prevent that.My impression was the opposite. It's 7-1/2"x2-1/2" and I don't think it's 1/4" thick. It's "engineered" which means it's shaped and built to take loads in certain ways, while minimizing material/weight which results in OVERALL strength being less than if you were in fact to take a foot tall 1/4" box. It is certainly not designed, as someone pointed out somewhere, to take the stresses of the tie downs combined with an out of aft CG/overload situation. And mind you, these exceedances are (percentage wise) well within what should be a reasonable engineering standard, say 25% or more. (I am NOT suggesting that overloading is OK. I don't.)
In my world the front wheels need to come off the ground first and then MAYBE things start breaking.
What's 7-1/2"x2-1/2" ? I think you lost me.My impression was the opposite. It's 7-1/2"x2-1/2" and I don't think it's 1/4" thick.
Outer frame dimentions?What's 7-1/2"x2-1/2" ? I think you lost me.
You said you thought the frame was 12" high. It's not. Not even close.What's 7-1/2"x2-1/2" ? I think you lost me.
I don't know if we're talking about the same thing. I'm talking about the transition area of the frame right behind the cab of a 3500 chassis cab truck. It's substantially more than 7 1/2" high.You said you thought the frame was 12" high. It's not. Not even close.
Made me get under there again, in the wet cold. The chassis beam is 7-1/2" all the way. To the left is the rear cab mount, the square tube at the bottom left is my TC tie down seen in the more distant shot.I don't know if we're talking about the same thing. I'm talking about the transition area of the frame right behind the cab of a 3500 chassis cab truck. It's substantially more than 7 1/2" high.
You would not have to get under it again if you read where we talked about C&C trucksMade me get under there again, in the wet cold. The chassis beam is 7-1/2" all the way. To the left is the rear cab mount, the square tube at the bottom left is my TC tie down seen in the more distant shot.
