I'm hoping someone can provide insight into this. @Jimmy07 and @Brutal_HO, if you have time for any input, I appreciate it.
I took delivery of my 2022 Laramie 5500 60" CA a couple of weeks ago.
Is there any way to verify that I have received all the "loose" shipped items that are supposed to come with the truck and the correct part numbers? I'm hoping to get this figured out so that I have everything I need when I have a flatbed installed. When I asked the dealer, they said that Ram didn't provide any list, that the items should just be in the truck. When I asked how do we know if something was missing... they had no idea.
Here are the options I ordered:
Laramie level 2 equipment group
Safety group
Towing technology group
Trailer tire pressure monitoring system
52 and 22 gallon dual fuel tanks
Heavy duty snow plow prep group
Cold weather group
Full size spare
Manual DPF regeneration
Off road tires
Here are the "loose" shipped items I have:
Tow mode camera install cable 68527158AA and connector plate 68508681AA
Rear view digital camera kit 68544395AA, with cable 68544396AA and camera 68442521AA
TPIS kit 68395315AC , with harness 68396015AC and module 68526635AB,
Wheel sensor kit 68433188AA with fittings and wheel sensors (4) 68375992AA
7 way / 12 pin connector plate 68522624AB
Fuel filler extension kit (2) 52121693AH
Cold weather radiator cover 68526832AA
Aux switch / upfitter wiring kit 68512072AA
VSIM module wiring kit 68361228AC
I've done a lot of internet searching and a lot of the part numbers on my stuff either can't be found or don't match up with the Ram body builder guide sheets on their site. I'm a little confused here.
A couple of other things I've noticed.
First, the 7 way wire harness at the back of the chassis is just blunt cut and shrink wrapped (as shown in the body builders guide). There is no quick disconnect harness included to splice to this and connect to the 7 way / 12 pin plate. Is this typical?
Second, the rear view camera has no mount or bracket for install. The body builders guide seems to state that you have to handle this yourself? How the heck do you mount this thing? I've included a pic of just the camera.
Thanks for any help.
Safety group
Cold weather group
Full size spare
Off road tires
