Slightlyhigh
- Joined
- Mar 22, 2021
Did the Compact disc player become discontinued 2021 ?
Nope my 19 has one the last year was 2020CD players were discontinued in 2017 or earlier, my 2017 Sport did not have one, they are available as an option
You could i think but idk what you would need, mine is under the center seat but i did see some with the console that had it in the dash if i remember rightCould I adapt a 19 to 21 model ?
19 and older was a cubby under center bench seat i was told 19 was the last year for the underseat cubbyI think Jimmy07 has posted about this in this or the Modifications forum.
Try searching there.
Do the 21 have the cubby where the CDP would go? You might also have to acquire that part or do the setup for a CDP in the glovebox. I believe the 19 & older had a glovebox mounted changer as an option.
Interesting i was told by dealer only the 20s had it in the lower dash my bad lolThe 19 higher trims had a CDP in the lower part of the dash under the radio. That's the one I was referring to.
I found what I believe to be the CDP part number in a post, but haven't seen anything definitive for the hookup/wiring. This is the one that would fit into the dash cubby.
68335565AB but I would check this part against a 2019 VIN with the option.
Cubby panel
Not sure when but mine did not come with one. I probably would not have used it anyway. I just ripped all my CDs to a USB stick.Did the Compact disc player become discontinued 2021 ?
This^Not sure when but mine did not come with one. I probably would not have used it anyway. I just ripped all my CDs to a USB stick.
You are correct. My comment wasn't meant to try and answer the original question, as you already did that in the 3rd post.Responses like these come up often and are not helpful to the OP original question.
Let's offer some suggested alternatives to consider instead of just saying everything sucks...
I know it's hard to believe, but sometimes the OP has already put some thought into alternatives and just wants a question answered.
Is it better to use USB? Probably. Maybe that's not what @Slightlyhigh wants to do? Not everyone has the ability or desire or perhaps the time to rip everything to digital.
Personally, I think it's dumb to put music on a USB stick when I have a 256GB sdcard in my phone that stores everything and continually syncs to my media server. I can play it via BT or USB or my wireless BT ear buds when traveling.
My suggestion was simply meant to suggest a cost-effective alternative.Discontinued in 2020 across the HD lineup (trims) and not available as an option.
Most trucks got a cubby where it was located, some did not.
