R.J.
- Joined
- Jan 22, 2019
This is eating at me a bit lol.
Measuring the trackbar accurately is wonky itself - IDK + or - 1/16" or an 1/8" (At worst). 39 1/8" total if you have the 3" coil springs.
The axle is clearly biased to the left (Drivers Side) at static height perhaps a good 1/2" to maybe 1" eyeballin . I notice it cause I'm looking for it, but most wouldn't even give it a second thought.. I haven't taken any official measurements so it's just based off of line of site down the sides of the truck.
I was thinking of pulling the trackbar again to double check my measurements. I mean the truck aligned fine with caster and toe, but I'm not sure if the machine would measure axles that are side stepped like this? IDK, if the bar needs to be readjusted, the thought of fighting the red Loctite is giving me anxiety. Torch and big ass wrench? haha.
The other "issue" is the thrust angle measured .12 degrees at the rear axle. I've done the Carli Add a Packs here so not sure if I should let this ride or make an effort to loosen u Bolts, shift it around a bit, and then retorque.
IDK, Am I overthinking this?
