Hi, I just finished installing a suspension system on my 2500 Cummins, and I am surprised at how harsh the suspension still is. I installed Thuren +2 front springs and the Thuren stock height mid-rate rear springs, along with Thuren track bar, and Thuren sway bar links. The shocks were Carli King 2.5 Pintop. Running 37x12.5R17 Kenda Klever RT on method HD wheels.
I know this kit is a mixmatch of brands, but the guys at CJC seemed to think it would work. I chose these components based on availability, and the fact that I wanted as minimum lift as possible to clear 37s. The truck tracks really well over the rough stuff at high speed but it's still extremely jarring inside, which I didn't expect given the videos CJC puts out of them slamming whoops and jumping these trucks in the desert. The spring rates really don't feel that much different from stock, and I don't feel like I've lost any carrying capacity over stock.
Is there a common mistake on install that could cause the shocks to bind? I have a couple thoughts:
1. In the instructions that came with the Carli shocks, they said the shocks are often not properly charged with nitrogen from the factory and sometimes need to be reset to 225 psi (can't use compressed air). I have been unable to verify the pressure as I don't have a way to apply 225psi of nitrogen to the shock
2. Sway bar - I still have the stock front sway bar because both Carli and Thuren options are out of stock. I plan to install one of them when I can, hoping this helps. In the meantime should I try disconnecting the front sway bar to see if it makes much a difference?
3. Break in/cold weather - I only have put about 125 miles on the setup, and it's been all in <20F temperatures. Do these shocks need to break in? Do they get really stiff at cold temps due to the oil getting thicker?
4. General incompatibility- is it possible that these kits just can't work together? That seems a bit hard to believe, but did I make a mistake by mixing and matching kits?
5. Alignment - I haven't gotten the truck aligned yet, but I will tomorrow. There are no other strange driving characteristics other than the ride being really stiff still, and not sure how the alignment being off would cause this.
Anyone have a similar experience? Maybe my expectations are off for what is possible in a solid axle HD truck. I just don't feel the amazement at how much better than stock the ride is that others have expressed. I haven't tried any rock crawling or anything, that's more like a summer activity here.
