Coming from a gladiator on 37s and 3.5” lift. I know already neither the Rebel or PW will be exactly like it.
I tow a 6000lb loaded trailer. Tongue weight is about 765 to 1100 depending on how much water is in the 54g tank. Gladiator isn’t cutting it on either power or payload.
With the PW hooked up to the loaded trailer I’ll be right at payload capacity without water in the Trailer. With my family in the truck and cargo, etc. I’ve done all the calculations correctly. Yes I went to a scale.
I know the disadvantage of the rebel Cummins is the additional 1000lb weight, no front locker, no disconnecting sway bar. But, does anyone know if you can get decent flex if you disconnect the sway bar manually?
I still plan on going on hells revenge in Moab and doing hells gate and such. I’ve done it in gladiator. I’ll definitely do it in the Pw. Still unsure about the rebel cummins.
With The rebel Cummins I’ll have additional my payload (300-400lbs more) to fill my water tanks and hold more gear. Or if I decide to upgrade to bigger 40” tires down the road.
Any words of wisdom?
