Buzzing sounds coming from 2020 ram 2500 diesel
Duneboy714
Dec 26, 2020
Hi all, I noticed a buzzing sound the other day but it went away.. today after doing oil and fuel filters charges I was able to hear it more clearly. Buzzing happens only when car is in park with foot on brake. What could this be?
2020 ram 2500 diesel 6.7
54k miles
Let me know your thoughts and if anyone else is hearing this too
flan
Aug 16, 2019
Where is the buzzing coming from?!?
Sounds like lifters @CTF2019 can confirm he has been dealing with the issue for a while
flan
Aug 16, 2019
So when you step on the brake that’s the change in sound?
Duneboy714
Dec 26, 2020
Correct.. when truck is in park and you press on the brake is when you can hear it.
Doesn't seem to happen when truck is in drive
If thats the case it could be something with the powersteering or hydro boost. Would be best to poke around with a stethoscope
Fairly normal for the power steering pump/hydroboost. You’re not at the OEM service interval, but it couldn’t hurt to use a turkey baster to empty the PS pump reservoir and add new ATF+4.
I do that every oil change.
