Went ahead and did it on my 19 PW just now, AC Delco hose from the link above.
The rear was already run pretty high, about to the floor of the bed…but the hose was so loose on the axle that it pretty much fell off when I touched it and the check on the end was a plastic version of the old school bobbler, a loose cap assembly.
The factory hose had clips and abrasion protectors on it so put a squeeze clamp on the axle barb, cut off about 3” on the other end and used the lil’ Wix steel fuel filter as a coupler to add the new section to the older. Pulled the driver tailight, ran the hose up to the bed rail behind it and put the factory check on the end with a clamp. Didn’t need many wire ties due to the factory clips that got me a ways there.
The front was clamped securely to the barb, about 3” long and had the Goretex check on it. Pulled the check and coupled hoses with another filter, used some split heater hose to make a chafe guard where the slack sits on top of the diff yoke and ran it up to the driver’s side top of the firewall just under the hood wire ties along the way. Put the Goretex check on the end with a clamp.
The factory hoses are slightly smaller than 3/8ths but coupled up fine, I left them for ultimate sealing on the barbs instead of using the slightly too big 3/8ths hose. The lil’ front filter is riding close to the diff but it weighs nearly nothing especially with no fuel in it, I smacked it around and it won’t touch. I may pick up a 3/8th barb both ends brass fitting to couple and move the filter to the firewall zone, or not.
