oscar
- Joined
- Nov 18, 2021
Getting ready to change fuel filters/water separator. Done this more than once on same engine in Motorhome. Except there I pre-filled the filters on the dirty side. Even came with a nice plug to close close up the clean side.
The most real looking video I found for these trucks, although same engine said that after replacing filter (I like to do one at a time to narrow any issues should they arise) you place the ignition in "RUN" (not starting) for 30 seconds, turn it off and do that two more times. This will prime the system and expel all air? So...... where does the air go? I know running air through the high pressure pump is a bad idea..... Years ago on my Chevvy there were bleeds in the system......
