I've had good luck with ADCO All Climate + Wind Designer Tyvek covers. They will wear in the corners, but I had a cover that was used during four winters that was good enough to be sold with the trailer. The wind can be tough on them, so check the cover frequently.
You know the ‘net has a wide variety of opinions on certain subjects..The cover fans said if it’s a quality cover with plenty of securement it will be good. Then there’s the ThEy TrAp MoIsTuRe crowd.
Hey OP good luck either way you go someone will tell you you’re doing it wrong
