Bed switch panel
P8trit
Sep 6, 2023
So I'm wanting to install some bed lights under my RTT mounted to the cross member of bed rack. I would like to run Battery power using 44Dan44 instructions to a switch panel isolating different lights but I can't seem to find a panel that I don't have to cut a hole in bed. Maybe a panel that mounts under the bed rail?
Looking for suggestions, thoughts and wisdom..
deanfx
Jul 2, 2023
Why not a panel inside the cab? Do you have aux switches? If not how do you feel about Auxbeam?
JustMeAndMy3500
Dec 10, 2023
Try looking to a marine application supplier. They have way more choices than automotive. So many applications, higher quality and most if not all are waterproof. Anything I've mounted under hood or exterior somewhere, I've gone this route on many of my projects.
P8trit
Sep 6, 2023
I do have aux inside and I will use 1 to turn the power on to back of truck but would like a control panel to be able to control when stopped at camp.
P8trit
Sep 6, 2023
I have looked but so far all seem to require a hole in the bed but this weekend I should have some time to better search
