Rockcrawlindude
a rock crawlin’ dude
Good morning all.
Problem: I have an older car that does not have a very robust charging system. I’ve been through it and fixed parasitic draws that it had. I’ve replaced the alternator and the battery. Short of rewiring the car, I’ve got it working about as good as it can. It runs about 13.5v at the battery and about 12.4 at the dash on a good day. Overall, it doesn’t keep the battery charged very well. I guess it uses slightly more than it charges on a normal day with headlights and all that. I pull the battery out and charge it overnight occasionally (monthly?)
Solution? I’d like to add a battery tender to keep it topped off. I drive the car almost daily, so I’d like a permanent/ quick connect solution. The battery in this car is in a wet location, so the tender needs to be mounted somewhere else (few foot leads) or weatherproof. I also don’t know which tender I need. 800mA, 1.5A, 4A etc.
The battery in the vehicle is a 50Ah 650CCA
Any help and experience would be appreciated.
Duracell Ultra Gold Flooded 650CCA BCI Group 40R Car and Truck Battery - SLI40RT6M
Duracell Ultra Gold BCI group 40R replacement battery designed for low maintenance and dependable engine starting power. Perfect replacement battery for Ford, Mazda and more
www.batteriesplus.com
