It just plugs into the obd-ii port. Like a scan tool.Can you help me understand how this works? did you have to install sensors for everything or does it run off of factory sensors?
All the EGT and other data is pulled via the OBDII port? I thought sensores had to be installed which is why I never did it.It just plugs into the obd-ii port. Like a scan tool.
Yes. The truck already has sensors for all that. The tool just reads them via ob-ii.All the EGT and other data is pulled via the OBDII port? I thought sensores had to be installed which is why I never did it.
When pulling my 14K 5th wheel up a grade, I can approach 1000F on EGT1What is the hottest you guys have seen EGT's when working the truck?
I am in western NY so the uphill grades are not very longWow, ok. That is not very hot at all TBH.
For post turbo EGT’s that’s about as hot as you want to see. When I ran a pre & post pyro I would see ~10° difference per psi of boost, so 1000° on EGT1 could easily be 1350° pre-turbo. The EGT1 sensor is also further down the down-pipe that I ran a post turbo sensor which will decrease temps.
Does the stock egt sensor pull from post turbo? It was my understanding you always wanted your pyro in the manifold before the turbo....
