ghaynes754
- Joined
- Mar 25, 2019
i have the Aux Switch option and have run into a possible missing part. Looking at the kit bag with the instructions and wiring harnesses I see that on the instruction guide there is a Vehicle Wiring, Blunt end wire harness (location F) which brings battery or ignition triggered power to the back of the truck. To enable this circuit there is an open plug up under the dash just above the emergency brake pedal that needs a jumper plug inserted, described on the schematic as a Light Gray Port_Upfitters_2_D2621A_Body_D) and is part of the "Jumper (supplied Upfitter Kit to be installed by Customer)", page 7 in the instructions.
Doesn't appear to be part of the Aux Switch materials so I am looking for a part number for this kit. Side note this plug could also give you 12V power circuit into the cab.
