Is Smart Beam for auto high beam? If so here are the settings I enabled on my 2020 for auto high beam after changing out my mirror, along with everything else I've added.I finally got around to swapping out my mirror (2019 RAM 2500 Bighorn) for the Smart Beam Mirror and having one problem. I found a listing of BCM change on the Google Doc for Know Alfa Setting but can't locate one of the setting in alfa under Body computer MY2019 PowerNet. The item in question is "LIN & MISC: Smart Beam Present (AHBM)". If anyone knows if this still necessary for the 4.5 gen or if it's listed differently in the current android version of alfa your help would be greatly appreciated.
Anything I could have missed? I verified all 4 settings were correct for auto high beam, I have the right mirror and wiring and uconnect added the option to enable or disable them but when I put the lights to auto and push the turn signal lever forward nothing happens. No notification of them on the dash being enabled and no type of high beam light and no actual high beams. Works fine manually. Any ideas?Is Smart Beam for auto high beam? If so here are the settings I enabled on my 2020 for auto high beam after changing out my mirror, along with everything else I've added.View attachment 38451
Tried it this morning and it’s working fine now.Anything I could have missed? I verified all 4 settings were correct for auto high beam, I have the right mirror and wiring and uconnect added the option to enable or disable them but when I put the lights to auto and push the turn signal lever forward nothing happens. No notification of them on the dash being enabled and no type of high beam light and no actual high beams. Works fine manually. Any ideas?
You will need a new harness. The one you need is not there most likely. There is a thread in here with the part numbers and changes with Alfa obd.Just did this a couple days ago. Super easy. Drop the front of the headliner, run the new wiring from side of glovebox up pillar and re clip all connections into new wiring and then plug last clip into mirror. Use Alfa obd to activate and done. Took me about 30 minutes
