Seat heater maybe?For my 3500 Tradesman this plug is not used. I am looking for a wire that I can tap into under the seat that is hot when in run
Maybe, of course it could also be for power seats. What I need is for someone with power seats to look under their seat and see if this plug is connected to their seat.Seat heater maybe?
Kanuter valve connector.
Thanks, thats what I thought. Now I know that it will work for my project. AwesomeView attachment 4211
Looks like the correct plug by the wire colors. If so I can only tell you they are going to some control boxes under the seat right above and to the right of the pictured plug. I do have heated and cooled seats with electronic adjustments on a 2019 Laramie 2500. If you need better pictures let me know. It was raining when I took this so I hurried a little.
Thanks, I will get out my multimeter and get busyI believe the Tech Authority documentation confirms that is for the Comfort Seat Wheel Module (CSWM). Unfortunately, I don't have a wiring diagram to help you decide which wire to splice into.
"A CSWM is used to control the front heated seat system. The CSWM responds to heated seat switch messages and ignition switch status inputs by controlling the 12 volt Direct Current (DC) output to the front seat heating elements through integral solid-state relays."
What are trying to power? The reason I ask is if a hot in run wire dedicated to another application is used and power is routed through one of the motherboards. You can fry it. Much more of a problem than just finding an unused hot in run circuit at the fuse box. I cannot tell you how many pieces of heavy equipment I lost main boards in because of someone doing this. These trucks are no different. Just a thought.
Hey, do you have documentation that would show the wiring and install location for the power running board module? I would very much like to see it if you do, thanks!I believe the Tech Authority documentation confirms that is for the Comfort Seat Wheel Module (CSWM). Unfortunately, I don't have a wiring diagram to help you decide which wire to splice into.
Thank you very much!I just replied to your other thread on the power running boards.
