Antifreeze leak on 2020 RAM 3500 6.7 engine
Edi
May 7, 2024
I'm new with RAM trucks. I got an antifreeze leaking from the location in this picture.
Can someone tell me if this a Heater core leak, or this outlet goes somewhere?
Thank you in advance
Thank you, I can't find the antifreeze leak. I can smell it, and I have to fill the reservoir once in a while.
Engine oil is clean.
How often is once in a while? Any signs on the water pump weep hole?
flan
Aug 16, 2019
Have you seen it coming from the ac condensate drain tube pictured in the photo?
Every 400 miles I haveto add a quarter of antifreeze, water pump isn't leaking.
Thats a significant leak you should be able to see the antifreeze or significant staining where it is leaking. If the A/C drain is leaking antifreeze like you say then the heater core needs replacing but you should have a sweet smell on the inside of the truck and when using the vents your windows would be fogging up
Edi
May 7, 2024
It won't smell inside , but yes I see liquid coming out from the outlet showing in the picture.
That should be just water coming out, if it does not smell inside it’s not a heater core failure. I would recommend having the coolant tested for combustion gasses you can buy the test strips.
