Alternator Amperage
Either 180A or 220A you would have to either check your build sheet or check the part number. If you stop by your dealer usually they can print you out the option sheet.
is the 220 alternator a direct swap for the 180 amp? 2017 HO and looking to replace with higher output alternator
