Air Locker For 3500 Dually
Ram01
Dec 17, 2020
I want to see if it's possible to add an air locker to a 3500 dually. I know you can do so in the front, but can you do so in the rear? I found one by ARB, the ARB RD 139, but it mentions that some duallys might have a 16 bolt ring gear and if that's the case it will not be compatible. Which 3500 duallys have the 16 bolt ring gear, is it all of them or only certain duallys?
Thanks
regal2800
Apr 23, 2019
do you have the HO 3500? the HO 3500 uses an aam 12 while the regular output uses a 11.5. I am not sure though if the 11.5 has different bolt pattern on the dually.
Ram01
Dec 17, 2020
It's not the HO, but it is a dually. I know Ford changed their bolt patters in 2017 so they're no longer compatible even though they're still Dana 60s.
