Ahhh the struggle...
flan
Aug 16, 2019
Usually the vent in the tube does it’s job and it flows out nicely. I’ve only had it do this 1 other time in 21k miles.
McHenry2500
Aug 20, 2020
Why?
Just pull into a station that has bulk DEF - it's more convenient and often less expensive without the mess - my $.02
These are getting to be more common in my area. 4 years ago I think I saw 1 or 2. Now I have 3 just in my town with the DEF pumps.
wrvond
Sep 20, 2023
West Virginia, USA
Why?
I much prefer getting my DEF from a single use jug. It’s much easier than wrestling with a retractable hose that doesn’t work right and I’ve never been a fan of nozzles crusted over with white crystals.
Never had a problem using the WalMart brand and like having a couple jugs stored in my basement.
flan
Aug 16, 2019
Are the magnetic collars still a thing on def pump nozzles? When the truck stops first started with pumps I recall our trucks needing a adapter to let the def flow out of the pump nozzle. The commercial tanks have one built in where our fill neck does not.
CdnHO
Nov 17, 2020
Ontario
I have used the DEF pump at truck stops. No adaptor was needed. I would think if an adaptor was needed, then it would be marked on the pump?
2001WS6
May 30, 2021
KY
I have a funnel dedicated for DEF. Screw that cheap flex hose.
Funnel
ppine
Mar 11, 2023
Nevada
In the West we get the square jugs with a vent and a spout. Totally simple to use.
