Adding 7 pin trailer plug in bed of 2022/2023 3500 - is harness pigtail underneath?
Ram Tuff Fred
Aug 31, 2022
Does anyone know if the 2022/2023 Ram 3500 Dually has a wiring harness pigtail somewhere underneath towards the rear to plug in the wiring harness from the 7 pin plug you add in the bed? I assume it would be the same harness that the 7 pin bed plug would be plugged in if it had come from the factory with one. I had a Ford F350 Dually that had a pigtail from the factory already underneath, so I purchased a Ford factory 7 pin plug and mounted it in the bed and just plugged it in the pigtail. Thanks
These trucks you can just buy a T harness that plugs in to the back of the 7 pin at the bumper Curt makes a kit for putting the bed plug in the box aswell
The 7-pin at the bumper is a pigtail/connector so as hellzipper said, just get a kit and/or the Curt pigtail. Y could go the factory route but I'm uncertain if all the parts can be sourced or what those PN might be.
MooneyFWD
Dec 11, 2020
This is what I did. Cheap, easy, and works great.
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
this is the one i used. they're all about the same.
Ram Tuff Fred
Aug 31, 2022
Thanks to everyone for the quick replys. I'll measure 1st, but I think the 7' Curt harness should be long enough. I love plug and play connectors. Also, I read somewhere that you can only use 1 of the 7 pin plugs at a time, either the one in the bed or the one on the rear bumper. Not that I know of any reason to need both 7 pin plugs at the same time, I thought that was odd but guess depending on what would be plugged in, you could overload the circuit. Thanks Again.
Fred
Fred
To my understanding they are what is used from the factory so you should have no fitment issues
