Jnrcarson
- Joined
- Nov 28, 2021
Are those factory fender flares?35s (285/75 18) w 1” front level View attachment 24905View attachment 24906
They’re bushwacker “Oem style”Are those factory fender flares?
Thanks Rockcrawlerdude. I have a 2022 Trradesman 2500 diesel coming soon. I’m going with method wheels +18 offset and 285/75/18 ridge grapplers, Carli leveling kit, and track bar. Just worried about what little bit the tires might stick out. Might add flares at some point. Think I’ll put on the Go Rhino running boards as they might help with stray rocks up the sides.They’re bushwacker “Oem style”
Is that 27 positive or negative offset?17x8.5 with 27MM offset works really well with 35x12.5-17's. no rub anywhere and very little crap gets flung on the side of your truck or door handles.
PositiveIs that 27 positive or negative offset?
For those who can’t see his sig line they’re 18x9 -6 with 305/70-18She rubs a bit, took off the little factory splash guard which helped a little but i'm going to attempt to heat and re-mold the fender liner and see if i can get enough clearance without having to cut.
But what is that in real tire sizes? LOLFor those who can’t see his sig line they’re 18x9 -6 with 305/70-18
Around 35x12.50But what is that in real tire sizes? LOL
I am surprised it rubs then.Around 35x12.50
It’s the offset and width, I assume.I am surprised it rubs then.
He has 1” more scrub radius (I think is the term) than I do, so I see why he rubs. Wheels pushed further out and wider tires
I have the same width wheels but 1/2” less offset (inward -18) and my tires are 1” less wide (285) and mine were very close to rubbing when stock.
I was really close to plastic (still pretty close) but not hitting any metal partsI would have thought that with the swaybar or arms. I didn't expect the liner to rub though.
