6 inch Power wagon lift kit
Michael Templeton
Aug 30, 2022
Hey Ladies and Gentlemen, I need some help. I have a 2013 Ram Power Wagon Laramie, I really want a 6" lift . All I can find is a 4" . I compared the BDS 4" lift for the Power Wagon vs a Ram2500 4x4 Hemi. I found out that the part numbers for each component is identical in every way. I have scoured the internet looking for 2013 Power Wagons with 6" lifts , A couple of photos claiming 6" but no links . BDS makes a 6" lift for 2013 Ram trucks with out Powerwagon as an option. My question is why wont a 6" lift fit a Power wagon? Is the sway bar disconnect the issue ? Any knowledge passed along would be appreciated. Thank you
jwindstein
May 5, 2021
if you’re looking for a true 6” over the stock wagon height, I believe BDS also offered an 8” kit which was simply the 6” coils with a 2” front coil spacer. It may have even come with a 5” rear block instead of a 4”. Could be an option for you.
jwindstein
May 5, 2021
I don’t see it on the site now but they still have the 8” long arm.
Michael Templeton
Aug 30, 2022
Thank you for the heads up.
Michael Templeton
Aug 30, 2022
thank you
