6.7 HO vs 6.7
EEBTTF
Jan 16, 2019
I understand that the 2 are the same engines with different transmission options and different tune/turbo (I think) on the HO generating the higher torque and HP. Aside from the higher towing numbers with the 3500 - is there a major difference in the everyday driving performance of the HO over the regular. I am torn between the 2500 and 3500. My biggest trailer is a 14.5k bumper pull - my current 2500 does fine, but I have never been impressed with its performance for everyday driving (Im comparing this to my old 6.7 Powerstroke)
D
Deleted member 80
Guest
I would definitely go HO, even if just to get the Aisin.
EEBTTF
Jan 16, 2019
I agree on the Aisin. I'm not sure why Ram doesn't make it a standard on all HD models. Can you tell the difference between the 2 engines performance wise when you are not towing? The difference in my builds between a 2500 and 3500 is $3k.
D
Deleted member 80
Guest
I would have to believe that the difference in torque would be noticeable even empty, bearing in mind that the Cummins is a slow turning workhorse engine, not a V-8 winder like the other guys. They may not win the stoplight derby, but there is nothing more satisfying than that "old tractor rmotor" just loafing along with a heavy load in tow. Six-in-a-row, the only way to tow!
Heckyl
Dec 20, 2018
I think you have to get 3500 DRW to get high output with aisin. Don’t think it’s avail on 3500 SRW if that is what you are considering.
Heckyl
Dec 20, 2018
Actually I looked it up and I stand corrected... you can get high output in SRW 3500, sorry.
Don-T
Feb 4, 2019
I have a 3500 on order. It has the HO with the Aisin and it is a SRW. I don’t know yet it it has the 3.42 or 3.73 axles. I have found conflicting information on this.
Don-T
Feb 4, 2019
I just heard back from my dealer. He contacted his factory rep and was told all Ram HDs for 2019 will have 3.73 as standard equipment. No more 3.42. When I can get a build sheet or the window sticker maybe I can confirm. The 2019 towing and payload chatted I now have also say 3.73.
D
Deleted member 80
Guest
That's good news!
DevilDodge
Nov 21, 2018
Age
46
Central Pennsylvania
Yes across the line, 3.73 is standard gas/diesel 2500/3500. 4.10 is the option. But only gas/2500/3500 and diesel/3500/dually.
And Powerwagon is standard 4.10
Stumblefoot
Mar 5, 2019
I wonder why RAM isn’t offering the 4.10 option on the diesel 2500/3500 SRW?
