Tsys100718
Thanks, If I can get 7' I will be fine. I think it runs about 6'8" tall with the tires and lift. it is 65" wide and 108" long. The only concern I had was the height and I figured I could lay the couches against the wall. I have also read where that camper has the cut outs on the corners for tighter turns with short bed trucks. I think I will be fine with the super glide single point for the lighter weight or the B&W for standard hook up. Which hitch do you run with yours?
The front cap does indeed have swept back corners designed for shorter bed trucks. Another thing I would consider, and I did it to mine, is replacing the self tapping screws that hold the D rings on the outer two rows, to the floor with bolts, washers and nuts. Again, it's a matter of preference but I did not want to trust my trike to 3 in self tapping screws! While it is true that the screws go through a thin metal strip underneath, I felt better replacing them with bolts. It took maybe an hour to do this and cost around $20 or so. Again, just my 2 pennies worth!
