I was content to just let it be, but now I've completely lost my brakes altogether. I confirmed they are adjusted properly, I've done the burnishing. There are two wires going back to the brakes. One is power (tied to blue wire from truck and 12v breakaway) and the other is ground. They both split into a pair of wires to each axle, which then split again to each side of each axle. At that junction, when I pull the breakaway switch I get 11.67v while sitting still, but can still rotate the tire by hand with pretty much the same amount of force as when not engaged. With just the slider and gain set to 10 on heavy electric, i get 8.5v coming out of the trucks 7-pin connection but only 3.64 at the junction of the wires near the axles.
I've ohmed all the wires and there is virtually no voltage drop.
If I'm getting power to the brakes, why aren't they engaging? I can hear them, they just aren't doing anything
Edit: even with gain on 10, the slider will not slow/stop the rig at 5 mph
